coolpi 4b python3 gpio operation compatable with raspberry pi
download and install with root user.
sudo pip3 install CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl
for ubuntu 20.04
CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whlfor ubuntu 22.04
CPi.GPIO-1.0.0-cp310-cp310-linux_aarch64.whlother
CPi.GPIO-1.0.0-cp39-cp39-linux_aarch64.whldefault gpio cfg with system image:
gpio_coolpi
running test:
sudo python3 test.py
#!/usr/bin/env python3 import CPi.GPIO as GPIO import time PIN = 40 GPIO.setmode(GPIO.BOARD) GPIO.setup(PIN, GPIO.OUT) while True: GPIO.output(PIN, 0) time.sleep(1) GPIO.output(PIN, 1) time.sleep(1)
其中GPIO.setmode(GPIO.BOARD)表示使用coolpi 4b板子自然编号Pin number。如果要使用Rockchip gpio编号,需要引用GPIO.setmode(GPIO.RK)。
if you want to remove this module, exec command:
sudo pip3 uninstall CPi.GPIO
也适用于debain等其他系统嘛
@花月 注意python版本,其它都是一样的。ubuntu22.04 默认python3.10,要注意切换一下。
@george SPI 怎么开,在debain下安装完输入gpio_coolpi显示命令找不到
是否有比较全的示例介绍SPI -
@花月
系统中若无该命令,请将附件文件拷贝到/usr/sbin/,再执行chmod a+x /usr/sbin/gpio_coolpiSPI与I2C操作使用标准python或标准C调用API
@jack_admin 这个附件名称是什么,下载是数字的名称,有后缀嘛?
@花月 可以拷贝重命名/usr/sbin/gpio_coolpi
@george Is there any way to use GPIOs without sudo priviledge, such as in a ros package?
@dreamer
hi, please add extra operation for coolpi user.Add rules for normal user:
sudo echo "SUBSYSTEM==\"gpio*\", ACTION==\"add\", PROGRAM=\"/bin/bash -c 'chown root:coolpi /sys/class/gpio/export /sys/class/gpio/unexport;chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'\"" > /lib/udev/rules.d/99-gpio.rules sudo echo "SUBSYSTEM==\"gpio*\", ACTION==\"add\", PROGRAM=\"/bin/bash -c 'chown root:coolpi /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low; chmod 0660 /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low'\"" >> /lib/udev/rules.d/99-gpio.rules sudo reboot
Check rules:
coolpi@coolpi:~/Desktop$ cat /lib/udev/rules.d/99-gpio.rules SUBSYSTEM=="gpio*", ACTION=="add", PROGRAM="/bin/bash -c 'chown root:coolpi /sys/class/gpio/export /sys/class/gpio/unexport;chmod 220 /sys/class/gpio/export /sys/class/gpio/unexport'" SUBSYSTEM=="gpio*", ACTION=="add", PROGRAM="/bin/bash -c 'chown root:coolpi /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low; chmod 0660 /sys%p/direction /sys%p/value /sys%p/edge /sys%p/active_low'"
Test case:
coolpi@coolpi:~/Desktop$ echo 115 > /sys/class/gpio/export coolpi@coolpi:~/Desktop$ ls /sys/class/gpio/gpio115 active_low device direction edge power subsystem uevent value coolpi@coolpi:~/Desktop$ echo out > /sys/class/gpio/gpio115/direction coolpi@coolpi:~/Desktop$ echo 1 > /sys/class/gpio/gpio115/value coolpi@coolpi:~/Desktop$ echo 0 > /sys/class/gpio/gpio115/value coolpi@coolpi:~/Desktop$
请问跟RPi.GPIO的函数完全兼容吗?
GPIO.setwarnings(False) 之类的函数都有吗
@大法师 -
@AugustRobot_Zou
还未完整测试所有接口。 -
请问有支持python3.6的 .whl安装包吗?
我的docker环境是unbuntu18.04+py2.7+py3.6.9的,CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl安装不了。
或者有没有其他方式,驱动gpio -
@AugustRobot_Zou
所有的底层封装操作都是基于访问/sys/class/gpio/ -
请问能麻烦编译一个python3.6.9的安装包吗?
使用CPi.GPIO-1.0.0-cp38-cp38-linux_aarch64.whl,必须装上python3.8。
我的docker环境是ubuntu18.04+python3.6.9+ROS。装了python3.8后,同时存在python3.8和python3.6,导致原本的代码程序很多python版本适配问题,这几天为这个问题搞得头大,很难兼顾 CPi.GPIO库和原来的程序,模块脚本的#!/usr/bin/python3 只能配置2选1(3.8 or 3.6 )。
@AugustRobot_Zou okay!
@jack_admin @大法师
Really appreciate your help!
Now our system is basically compatible with coolp4B,which used to running on raspberry-pi4B. -
有python3.9版本的吗
@xingzhan2012 有。在帖子最顶楼
@jack_admin 谢谢
Does the coolpi have a DPI mode for the gpio like the RPI4?
@Macs said in coolpi 4b python3 gpio operation compatable with raspberry pi:
WiringPi ?
@jack_admin I mean can output video signal on the gpio using with custom timings, like you can on the RPI4?
请问支持C++语言吗
@Orion C++可以代码文件操作gpio,不需要调用python库
@jack_admin 请问C++需要包含哪个库呢,是writtingPi吗
@Orion 直接裸操作/sys/class/gpio,不做二次包装
it says in the GPIO page that all gpio are configurable with pullup or pulldown mode. How can we access the pull down resistor on a input pin say pin 32 GPIO105 that is default set to pullup? I tried the same convention as raspberry pi python access which is
GPIO.setup([pin#], GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
and i get the error no PUD_DOWN in the module. Can you post the entire documentation with included commands in this module?
@zensation not support setting pullup/down in user space now.
